Hi Guys
Has anyone run standard oe rubber front top mounts with an aftermarket coilover?
I know the logical thing to do is run adjustable top mounts, but sadly my hillclimb class doesnt allow them!! So need to run oe top mounts.
Technical hitch is the bearing sizes are small in the oe top mount to the bc racing coilovers.
Any thoughts welcome
yes very possible indeed i ran oem topmounts o0n the teins and d2 polos and rx7
al you need to do is take of camber mount / plate and slot on the oem 1 """ THO """" you might have to use a 2mm spacer depending on the top cup size
if your stuck just ask as i do a lot of this on the diy coil#s i do
