I need to order a set of calipers for the motor. Currently I have a single pot st202 setup with 260mm discs.
There appears to be a choice of two single pot calipers, one for a 255mm disc and one for a 275mm disc, and also a twin pot.
Does anyone know if these are interchangeable or which would be best to get?
Thanks for the suggestion although I had dropped him an message when I was first started having problems with my brakes but not heard anything back so not sure if he is still around
