Does the oil pump on these glanzas have a gasket? if so where can i get one and if not do i use silicone gasket maker as mine is leaking?
No gasket for the pump exactly but in the pump housing for the crank buddy if you look closely you will see the channels to follow on he back of it with some silicon sealant. But I would replace the crank seal in it wile your at it
Sent from my iPhone using Tapatalk
Ohhhhh saying there there is an
o-ring behind the pump either seated in the block or the pump housing
The oil pumps have an o ring to seal, if your block is a glanza your see a round grove on the block where you put the o ring
Oh yes I'm with you now mate my bad yeah you have to use some sealant but there are pics on the net about what exact places you have to put it on if that makes sense 👍🏻
