RobSR Posted April 16, 2017 Posted April 16, 2017 BC Racing BR/RM Coilovers for EP91 & EP82 * *image for illustration purposes, actual kit may differ. BC Racing Coilovers now available through Fiskë Automotive. Fantastic performance at affordable prices. We run a set on our demo EP91 Glanza to great effect. Multiple options available so please get in touch on info@fiskeautomotive.com to discuss your requirements and goals. BC Racing BR Coilover Kit EP91/EP82 - £849.00 The BR series coilovers use a large 46mm diameter piston in a 53mm diameter damper body to maximise oil capacity. As the damper unit operates the oil contained within heats up. The viscosity of oil changes as its temperature varies which can lead to changes in the damping characteristics of the unit.BC Racing only use a very high quality oil with their coilovers but go that extra mile to maximise performance and build their BR range with a large 53mm diameter damper body. This increases the capacity of the unit which increases the volume of oil contained which in turn reduces the peak temperature and so significantly improves damper performance.Pillowball front top mount included. Standard supplied spring rates F:6kg R:4kg however custom rates available. BC Racing RM Coilover Kit EP91/EP82 - £929.00The BC Racing RM series feature high quality damping adjustable monotube inverted dampers. The RM coilovers offer the majority of the features of the BR series but with the additional benefit of the inverted damper unit. Inverting the damper unit brings with it a number of advantages - Unsprung weight is reduced by moving the oil and gas reservoir way from the hub and attaching it to the shell. Unsprung weight is vital to a cars performance as a lighter wheel and hub assembly which readily moves in response to road bumps will have more grip when tracking over an imperfect road.Pillowball front top mount included. Standard supplied spring rates F:6kg R:4kg however custom rates available. Quote
