As in the title I think mine is faulty.
When I have the e01 hooked up the car won't boost past 10 psi.
I have played with the start, set and gain settings and even with it set 10 psi 100% 100% I only get 10 psi. .. it should be double that.
If I run just the actuator it will happily boost 14psi
Is this a faulty solenoid or a e01 config error?
I would do the auto setup but don't have access to a decent enough straight or rolling road to do so
Are you sure there's not a leak in the controller vac pipework somewhere?
Surely if you have a 14psi actuator then the no matter what the boost controller is set to the minimum boost would always be 14psi.
No leaks cause if I put a boost tap in place of it I get the 14psi I'm after.
The start boost is set on the actuator arm and the max boost is defined by the spring.
The solenoid holds the wastegate closed until it hits the boost i set it to... or should do if working properly
