gaztop101 Posted May 3, 2017 Posted May 3, 2017 so I have removed both camshafts to do the valve stem seals, I have done everything right ie making sure crank set to tdc, and cam marks lined up, but after removing the dizzy the spindle on the bottom that sets into the end of the cam has been turned, I have marked the position of the dizzy body in relation to the head but need to know the spindle is in right position when re fitting, any tips, thanks Quote
5e colin Posted May 3, 2017 Posted May 3, 2017 been a while but i think the spindle only slots in 1 way and bolts/fits on 1 way to the dizzy main shafts worst you can do is have a no starter if so see if dizzy spindel to camshaft fits 180egree Quote
gaztop101 Posted May 3, 2017 Author Posted May 3, 2017 cheers for that, i just thought that the spindle turns the rotar in the cap, didint want it pointing to wrong ht lead, if you know what i mean Quote
5e colin Posted May 3, 2017 Posted May 3, 2017 i know what you mean i just checked there on my old dizzy there's a groove that has to face upwards also spindel security point is of center so cant be fitted wrong Quote
