hey guys i need some topmounts has to be gtturbo as glanza is a narrower shaft
any abouts ??
or mint camber plates no play or knocking
if you have oem mounts then you need to measure the hole of the topmount bearing
cheeers 5e colin
thats fecking great part is discontineud by mister yota us gtturbo boys are fucked
our topmounts are car model ( ep82gtt) specific dhuuuu the glanza shares with many more
The part numbers for the fronts is 48609-10110 (earlier models) and 48609-10150 (1994-1995) according to Toyo when those numbers are searched on ebay quite a few variants come up that might work.
Ive found a couple that might fit, but you will need to contact the supplier just to confirm
Check these out are listed for the earlier model starlet which I think share the same suspension.
And these list out ep91 but when u look in the title it says will fit earlier models to so contact them to.
