Gtstu Posted May 3, 2017 Posted May 3, 2017 Is any one using emanage on windows 7 or windows 10?I keep getting a communication box appear asking if I want to communicate in real time-click yes but it keeps coming up.I've tried a new usb lead but I suspect its a driver issue. Quote
hopalong_neil Posted May 3, 2017 Posted May 3, 2017 I ran into problems setting mine up also, turns out the drivers only work on 32 bit operating systems so if your running 64 bit then this might be your problem Quote
gorganl2000 Posted May 3, 2017 Posted May 3, 2017 as said above, you need some kind of "old platform" computer i had the same issue as you before, i was forced to buy a used laptop with windows XP (or older system 32 bit) an IT friend instructed me to create a partition, but that still did not work on the newer laptop (windows 8 i think it runs),,,the program would load and open, but still could not detect the usb connection to link with the emu Quote
