Top - vacuum pipe going to little inlet on the intake mani (you'll see where it is when you remove the old one)
Bottom - goes to fuel return line, again you'll see this when you remove the old one.
Side - goes to fuel rail via fuel rail adaptor.
Other side - you can put a gauge in here or splice one into the fuel line coming off the other side, depends what gauge you buy.
