Nathcox Posted May 8, 2017 Posted May 8, 2017 Would I be able to use a gt turbo engine loom and ecu on an na engine or are all the plugs different?Thanks in adavanve Quote
5e colin Posted May 8, 2017 Posted May 8, 2017 looks like you have p9 so yes very hard option best to use full glanze loom ecu and sensors Quote
Nathcox Posted May 8, 2017 Author Posted May 8, 2017 Got a mk3 gt rolling shell just needs engine and gear box was going to get an na engine put turbo pistons in it and try run that but was unsure wether the loom would run that engine Quote
5e colin Posted May 9, 2017 Posted May 9, 2017 ya sweet that will work loom will plug right to the rest of the loom in your gtt but again turbo sensors , injectors , coil/dizzy . TB , MAP , AIT , KNOCK and ecu needed you can run all strait fit when you have the loom just need to tap the thread for the knock sensor right next to the waterpump its M12 X 1.25 yes you can swap over 4efte pistons in the 4efe like me turbo G.I. block ( 100bhp N.A. ) lasted years Quote
Nathcox Posted May 9, 2017 Author Posted May 9, 2017 Cheers I'll be in touch if need any more advice Quote
