paddy Posted May 24, 2017 Posted May 24, 2017 My glanza cuts out at around 4000rpm or anything more than full throttle, at low rpm put your foot down and the engine cuts, feels like fuel cut but it's only running .6There's no engine warning light coming up, it's just had a change from trd to magencor leads, made no difference, it's hadNew fuel pumpNew fuel filterNew dizzy cap and rotor arm, It has Denso iridium 6 plugs which I'm gonna change but they look ok. Cars not been run in 6 years. Starts and ticks over fine and drives fine at very low rpm and minimum throttle anyone got any suggestion on what that problem could be? Throttle position sensor? Lambda sensor? There no engine warning lights coming up Quote
paddy Posted May 26, 2017 Author Posted May 26, 2017 Problem is throttle position sensor, it has the one with the orange sticker from a gt, where it needs the one with the purple sticker from a glanza Quote
