Bengt Posted May 27, 2017 Posted May 27, 2017 Is it normal for engines in the glanzas to run hot? Done about a ten mile journey , touched my bonnet after and noticed it was really hot , gauge is reading normal just under half way , just wondering if this is normal? Quote
5T4R7ET N/A Posted May 28, 2017 Posted May 28, 2017 The gauges will tell you if the car is running hot. I dont know if you have oil temp gauge or water temp but they are the two that will tell you if your running hotThe water temp wont go above 95 as the fan will kick in and bring temp down to 90The oil temp shouldn't go above 110. local driving should only get a 85-95. Its probably just a hot day and the bonnet was sitting in the sun and got hotter than normal, nothing to worry about Quote
Bengt Posted May 28, 2017 Author Posted May 28, 2017 Ok mate thanks , I don't have oil or water gauges but I'll invest in some just for piece of mind Quote
