Vinpetrol Posted June 12, 2017 Posted June 12, 2017 Hi I need a pair of front hubs , wishbones and standard springs for an ep91Mines had a minor front corner impact on one corner and I've fitted a new wishbone, lower ball joint, drop link and discs but for some reason the wheel is leaning out . I don't know what's making it out of line so if I put it back to standard and see if it lines up! CheersVin
morgey Posted June 12, 2017 Posted June 12, 2017 When you do the 2 suspension to hub bolts up you need to lift the wheel to take up the slack in the holes. Once thats done you'll need to get your alignment done as it will all be out.
Vinpetrol Posted June 12, 2017 Author Posted June 12, 2017 When you do the 2 suspension to hub bolts up you need to lift the wheel to take up the slack in the holes. Once thats done you'll need to get your alignment done as it will all be out.Hi Morgey Thanks for replying.So if I didn't do this would this explain why it's leaning out?What would I need to do to put it right? Cheers Vin
morgey Posted June 12, 2017 Posted June 12, 2017 Yeahif you just bolted it all with it just hanging then the top of the wheel will be further out than the bottom.Jack it up again, loosen the 2 bolts that go through the bottom of the shock and just lift thr hub from the bottom of the disc, you'll see how much movement there is where them 2 bolts are. All you need to do is lift the hub assembly by either propping with a jack or by hand then at the same time tighten them 2 bolts. Repeat for the other side. Take to a garage to get the alignment setup.
