Budnbass Posted July 21, 2017 Posted July 21, 2017 (edited) im currently putting my 4efte in my NA and I'm going to be using the NA engine loom and adding the extra bits needed for the turbo set up using a GT loom I've got and running a GT ecu with e manage. The pin out puts at the ecu look the same just in different positionThe Gt distributer set up is quite clearly different having a king lead to the igniter but would the NA distributer and upgraded HT leads to run a 4efte? Edited July 21, 2017 by Budnbass Quote
5e colin Posted July 22, 2017 Posted July 22, 2017 use 4efte dizzy only and use 4efte loom or leave everything na and map it on a sub computer dont mix and match it its trouble Quote
Budnbass Posted July 22, 2017 Author Posted July 22, 2017 I want to do minimal wiring changes so it would be much easier to use the NA distributer as it would be plug and play apart from swapping the pin out puts at the ecu. Does the 4efte igniter and distributer create a stronger spark having an igniter and king lead? Or is the NA version just more up to date?? Quote
5e colin Posted July 23, 2017 Posted July 23, 2017 The na dizzy can't work on the turbo ecu loom its more then just a few pin outs make your choice al na Or al turbo Best option is fitting al turbo electronics and sensors Quote
