I know this is a massive long shot, but does anyone have, or could take a picture showing the back of the ecu plugs showing what coloured wires go in which pins and it's got to be a 3 plug ecu preferably 89661-10110.
Just carried out a FTE conversion on my NA and I've rewirded the NA loom and added some bits of the turbo loom but I've got no spark.
I've got various pictures of ecu pin out puts and according to them All the wires are in the correct place but I'm running out of ideas I'm thinking mayb the pictures are wrong so would like to double check against an actually loom.
Would be a massive help if someone can come through with this!
post #13 shows some wiring for ep91 3 plug
http://www.ukstarletowners.com/topic/27821-socks-2zz-ge-turbo-glanza-v/
http://www.toyotazone.co.za/howitworks/how-a-computer-controls-an-engine/
http://www.toyotagtturbo.com/wiki/EP82wiring/EP82%20Starlet%20Wiring%20and%20Connectors.pdf
that's probably of little help to you, but its the most comprehensive wiring diagram i've seen for the 4efte 2 plug
Edited by gorganl2000
Cheers fella that's a great help. I've got the 3 plug version of the 3rd link that I've been following. I also had aload of photos saved of various sites but now photo buckets changed all the photos have gone!
I've come to the conclusion that the ecu doesn't know the cars cranking over so it's not sending a signal to the igniter to spark.
I've got a signal coming through the NE wire to the ecu when it's cranking so I just wanna make sure it's in the right place.
The only other thing that I thought could be possibly causing no spark would be an immobiliser but I was pretty certain an Ep82 ecu didn't have an immobiliser?
