Standard triggering is fine to run COP, you just need to use either 2 ignition outputs (wasted spark) or 4 ignition outputs (sequential) - depends on what your ecu is capable of. The 2zzge or K20 coils both work well, Ive setup quite a few over the years. Have a search, I've posted a bit about the COP conversion before with part numbers.
