Alright everyone! Got a few bits here that are just sitting around, which I don't see the point when they could be put to good use, have a look and whatever takes your fancy, drop me a Pm
All items except for the engine can be posted, however collection would be preferred from Crawley, West Sussex as I'm recovering from a few broken bones
EP91 optional extra plastic boot tray: £200
Fantastic condition, no longer needed as bought a rubber one which I prefer, just want to get my money back on this one
DSC_0340.thumb.JPG.8ac41d2af99c073cebe11
Paseo dials: (SOLD)
Good condition, great upgrade for N/A's, working prior to removal, I will polish the clear plastic before passing it on, milage displays as 46,499
DSC_0335.thumb.JPG.223b69985aa3852220ae3
SR dials: £45 (SOLD)
Fantastic condition, also great upgrade for N/A's, working prior to removal, plastic has been polished with all scratches removed, milage displays as 118,224 (can be matched to your mileage for additional £5), can also paint dials red by request for additional £5
DSC_0334.thumb.JPG.62f24ad13b42931aca1bb
TRD 1.5 mechanical LSD: £400 (SOLD)
This was fitted to a gearbox I bought, was told this worked as it should just fine, I have disassembled it to check inside and I do not see any obvious wear, I will leave bearings in place but is recommended these are changed when fitting new diff, I can remove bearings by request
DSC_0250.thumb.JPG.d2e70e78d10b643f3f17e
DSC_0248.thumb.JPG.bad28510712de8862ba7a
DSC_0247.thumb.JPG.b70a7dd4bc0c3da802568
Clark brothers instruments speedo converter: £40 (SOLD)
This was also fitted to the gearbox, and said to work fine, however I do not require, made in USA
_20171012_031312.thumb.JPG.4b3db7bc6dd70
EP91 '98 spec Glanza tail lights: £80 (SOLD)
Fantastic condition, imported from Japan years ago but never actually fitted, one is missing the rear seal but easily swapped over from your old ones, red lense was removed for reverse light (was going to be fit on an N/A) but will be included
DSC_0337.thumb.JPG.08707230d49c2a9234be0
DSC_0338.thumb.JPG.42fda053c47019fa9b43e
5EFHE bottom end: £180 (SOLD)
Bought this engine purely for the head and cams, haven't seen it running prior to removal but assured it did, the sera it came out of had covered 137k kilometres, cylinders look good, will come with Inlet manifold and throttle body (both same as 4EFTE), and water pump, would be good for anyone doing a 5E build or conversion
*collection only on this or please arrange your own courier*
DSC_0341.thumb.jpg.9ef30e78eafbaf1c21f56
DSC_0342.thumb.JPG.d8d7bddc704d4e85773a3
DSC_0343.thumb.jpg.1b7aaf8acdea6b1706257
DSC_0376.thumb.JPG.3184e448256e423ade9c8
DSC_0378.thumb.JPG.366db559208279f0cd89a
Hope everything is priced fairly, thanks guys
Trev
Edited by Trevstar
  • 1 month later...
