nano Posted October 13, 2017 Posted October 13, 2017 hi, I'm trying to auto tune with the greddy ultimate. my friend sent me a file with a target map. when I want to autotune the values in the i j adjustment won't change. I can see the yellow square but the values stays at zero which I guess is not normal. could someone help me for this. thanks Quote
gorganl2000 Posted October 13, 2017 Posted October 13, 2017 from past reports, this feature did not work for members, they ended up having to tune emu from scratch basically---i've only recall one member that said they got it to work, but i cant remember who it was at this moment do you have a wide-band connected to the emu?---i suppose this is a prerequisite for autotune to work?! Quote
nano Posted October 13, 2017 Author Posted October 13, 2017 yes I have a wideband. my friend has been using emu for a longtime. I get it sorted, the values are changing. I ve another issue . the car won't start when I turn the key on. I have to open a new file, like stock for it to start the car... Quote
nano Posted October 13, 2017 Author Posted October 13, 2017 1 hour ago, gorganl2000 said: from past reports, this feature did not work for members, they ended up having to tune emu from scratch basically---i've only recall one member that said they got it to work, but i cant remember who it was at this moment do you have a wide-band connected to the emu?---i suppose this is a prerequisite for autotune to work?! my friend is ramses and I think you know him as well. Quote
nano Posted October 14, 2017 Author Posted October 14, 2017 ok problem sorted. I didn't realise the green light was flashing (fouled plug feature) what I did is clicking "reverse" instead of "normal" in the throttle parameters. now the light is steady green. Quote
gorganl2000 Posted October 15, 2017 Posted October 15, 2017 On 10/13/2017, 1:06:33, nano said: my friend is ramses and I think you know him as well. yeah he should be able to give you tons of guidance. very experienced with these cars Quote
ramses Posted October 22, 2017 Posted October 22, 2017 (edited) he takes a lot of time to understand this , he wants to go too fast ( i can understand that ) ... he's now understanding that tuning is not only putting afr on table , but a kind of reliability as our fuel can vary from 91 to 97 ron Edited October 22, 2017 by ramses Quote
gorganl2000 Posted October 23, 2017 Posted October 23, 2017 On 10/22/2017, 10:27:26, ramses said: he takes a lot of time to understand this , he wants to go too fast ( i can understand that ) ... he's now understanding that tuning is not only putting afr on table , but a kind of reliability as our fuel can vary from 91 to 97 ron its all about optimizing the set up everything takes time to do it properly....will save troubles later on. if your gas quality varies so much, it might be better if you are on the conservative side ignition wise Quote
