1bar Posted October 18, 2017 Share Posted October 18, 2017 (edited) Hi Found out i have a crack in my oil pump got a new one how hard is it to change on a ep91 glanza? Any help or tips would be great. Cheers Edited October 18, 2017 by 1bar Quote Link to post Share on other sites
maddox710 Posted October 18, 2017 Share Posted October 18, 2017 Is the engine out? Getting the old crank pulley off can be a bitch. Be careful taking the main timing belt pulley off the crank, may need a puller. And make sure you torque wrench all the pump housing bolts up to spec. They only need a low setting Quote Link to post Share on other sites
1bar Posted October 18, 2017 Author Share Posted October 18, 2017 Engine still in the car. Quote Link to post Share on other sites
maddox710 Posted October 18, 2017 Share Posted October 18, 2017 You might find it easier if you drop that engine mount off and support the engine while it's tilted over be easy to access Quote Link to post Share on other sites
