Hey guys
I have a starlet gt turbo ep82
it has td04 conversion at 0.6 bar
jam ecu
fmic
dump valve
abd loads of other parts
it runs beautifully but it seems everyone and their dog has a starlet and they always seem to blow up?
i have paid a lot of money for this car and absolutely love it but I’m not a mechanic and if the worst happens then I wouldn’t be able to fix the car myself and I don’t want to own a money pit
it seems even if the afr is correct there are still so many factors that would cause the engine to go
are starlets reliable? Should I sell up?
  • 4 weeks later...
I had my gt for nearly 3 years without any problems! Only 1 thing went wrong and that was the oil seals on the ct9 turbo! But it had done 90k miles and was being run at 1 bar boost so was bound to go eventually haha
apart from the usual wear and tear items they’re as solid as toyotas come!
There strong engines at o.6 it will never pop only high milage and high revs will shit old bearings out  good maintenance is key to long life if you where to fit new bearings and rings it will last years at 0.8bar
