KRN Posted December 16, 2017 Posted December 16, 2017 Hi guys, Need some help here. Im in the proces of rebuilding an oem lsd gearbox for a Glanza. Since I also replaced the differential bearings does anyone know the preload figures for the bearings? And is this measured directly on the diff or via the external shaft (dummy placed). Quote
Stu Posted December 20, 2017 Posted December 20, 2017 I use a spare inner cv cup that ive welded a piece of flat bar and a nut to and use a torque wrench on that. I can't remember the actual preload but I found this with a quick google http://www.newcelica.org/forums/showthread.php?t=283040 Quote
KRN Posted December 24, 2017 Author Posted December 24, 2017 Yeah I saw that. Since I also have an oem LSD i am not sure to measure it directly on the diff or via the output shaft. And at what value, I came across some different values (celica, MR2). Not sure which one to use with the Glanza. Quote
