That Car Guy Posted April 18, 2018 Posted April 18, 2018 Do NOT do what I done and take the two bolts that connect the filter to the little bit of metal out first. I done this by mistake and ended up (in my case) snapping one bolt and having to use 7 cable ties... So beware. Take the top bolt for the line out and the bottom screw out first before you take out those ones, or else you'll have trouble... Quote
