Prime-Beardimus Posted April 22, 2018 Posted April 22, 2018 Hi there, My EP91 is not playing ball. She turns over fine, i have fuel going through the rail, all my leads are fine as spark tested the leads and plugs. Everything is working as it should but it just wont fire up. once she does she fires up fine a couple of times and then she doesn't want to play ball again and just turns over. any suggestions? Quote
SpikeyJp_68 Posted April 22, 2018 Posted April 22, 2018 Sounds like the ecu coolant temp sensor i had a similar problem. Does it only do it when cold or does it cold & hot ? Quote
Prime-Beardimus Posted April 23, 2018 Author Posted April 23, 2018 Both hot and cold. It is quite infuriating to be honest Quote
