i've not heard of any starlets running such massive injectors...are you thinking of E 85?
i personally run subaru sti blue 565cc injectors, after switching from rx7 460cc injectors about 2 months ago,,,,even in a relatively untuned state, the subaru injectors seem to be more driveable and are said to be more tuner friendly----i will find out about the latter part in a few weeks hopefully
also, that price seems rather cheap....just beware
Edited by gorganl2000
Thanks. I have managed to pick up some Impreza 565 blue injectors from a friend who has a subaru tuning place.
Only slight flaw I have noticed, the shorter injector, with short bolts and space tubes means the standard fuel pressure rreg fouls the the head
you may have a point there GordR regarding the stock fpr that i did not think about at all,,,,i can't even think of a reasonable fix for the fouling issue
if its not massive fouling, is it a part of the head that you can file away slightly to give yourself some clearance?
i run an aftermarket/SARD fpr, so its tucked away elsewhere, hence no fitment problems
