Hey guys, what sort of performance gains would I get from installing the 5efhe cams as well as the intake on a mildly modified 4efte?
  • 2 months later...
Think you would get gains from the cams, wouldnt really spring for the intake. Best suited for N/A purposes. It uses a vacuum canister which you would need to rig something up for that to work properly as well as figure a way to operate the butterfly valves (in terms of when they come on). Standalone & some piggyback computer can easily do this. If not, then a RPM switch will do it.
  • 2 weeks later...
