skans789 Posted April 16, 2008 Share Posted April 16, 2008 Just changed my thermostat and whilst putting it back on the 1 bolt broke, 1's on and 1's broke, there's no water leaking out of it so should it be alright, theres not much movement in it aswell?? thanks Quote Link to post Share on other sites
Guest Enzo Posted April 24, 2008 Share Posted April 24, 2008 i did the same the first time i changed it, if you can get some mole grips you could take the thred out?? Quote Link to post Share on other sites
skans789 Posted April 25, 2008 Author Share Posted April 25, 2008 i did the same the first time i changed it, if you can get some mole grips you could take the thred out??it doesnt move no water leaks out of it u recon it will be ok as it is? Quote Link to post Share on other sites
