ancaf33 Posted October 11, 2018 Posted October 11, 2018 Hello, since I just aqquired my starlet I am quite keen to have the timing belt changed. Should I change the waterpump at the same time? Do you recommend some specific brand? Also is this something I can do myself or should I let a workshop do it? Also if there is some other general maintenance that you would recommend, I would greatly appreciate it Thanks Quote
maerijn Posted October 11, 2018 Posted October 11, 2018 If its a 2E engine the water pump is not driven by the timing belt, so it can be changed separately depending on the mileage. I would recommend a timing belt by Continental, and ofcourse change the rollers aswell. You can also check if the crankshaft seal on the that side of the engine is still dry, if it is wet get a new one from the Toyota dealer. Quote
ancaf33 Posted October 11, 2018 Author Posted October 11, 2018 hmm how can I know which engine it is? Its a Toyota starlet 1987 1.3 DX Is it difficult to change by oneself? Quote
maerijn Posted October 11, 2018 Posted October 11, 2018 The engine number will be stamped at the exhaust side of the engine block.. but if its a diesel I am not sure Quote
ancaf33 Posted October 11, 2018 Author Posted October 11, 2018 Ah I will check tommorow, it is petrol Quote
ancaf33 Posted October 13, 2018 Author Posted October 13, 2018 I found my engine number, it is 2-e-c Quote
