whats the difference between standard N.A ep91 lowering springs and glanza ones
just after cheap lows car doesnt get driven hard on the road and will probably do less than 2000 miles in a year
but will be sent down the strip at the pod all day a few times a year
just wondering if i can throw stock ep91 lowering springs on and be done with it
As far as I know there's no difference I've had all sorts of lowering springs some cheap some more dear different springs depending on there drop act different ways if you just want a small drop 30mm would suit if you want to go lower 40mm I'd suggest some upgraded shocks I've 40mm springs on standard shocks and there horrid I've ordered new kyb gas shocks instead
All depends on budget and what you want from the suspension if you plan on a few strip runs get a good set of springs and decent shocks
