Heath Posted January 6, 2019 Posted January 6, 2019 Hi everyone, I’m currently swapping my 5efhte into a ep95. As part of the swap I am fitting a new aftermarket intake manifold with larger throttle body. It’s one of these common designs that you see around. Just wondering if there is any need to lengthen, replace or modify the throttle cable? Or should I be able to reuse it as is? Thanks in advance , Heath Quote
