Ben mcminn Posted August 25, 2019 Posted August 25, 2019 I want to change the engine in my 1996 n/a starlet to the 4efe our of a 1998 corolla has anyone wired the coil pack into the existing loom or do I need to change the entire loom Quote
Nanglebadger Posted August 26, 2019 Posted August 26, 2019 What's your reasoning behind swapping 4efe bud? Is the current one a little worse for wear? If its in an attempt to gain a few ponies, the engines themselves I don't believe are any different power wise, but you can swap the tubular inlet manifold over from the rolla engine to the EP, that's a fairly popular mod that usually sees a little improvement. Phil. Quote
