glanza 1 Posted April 20, 2008 Share Posted April 20, 2008 recently deresticted my glanza but car was not driving right, it was struggling to go when i accelarated. i put the restricter back on to see if that would help but is still doing the same thing, does anyone know it could be :angry: Quote Link to post Share on other sites
Toby@ToyTuning.com Posted April 20, 2008 Share Posted April 20, 2008 Hi there, Is it only hesitating at certain rpm ranges or as soon as you go on boost? Check your spark plugs, HT leads, Distributor cap, Rotor arm and Vacuum lines then report back when you can Best Regards,Tobyrecently deresticted my glanza but car was not driving right, it was struggling to go when i accelarated. i put the restricter back on to see if that would help but is still doing the same thing, does anyone know it could be :angry: Quote Link to post Share on other sites
glanza 1 Posted April 20, 2008 Author Share Posted April 20, 2008 Hi there, Is it only hesitating at certain rpm ranges or as soon as you go on boost? Check your spark plugs, HT leads, Distributor cap, Rotor arm and Vacuum lines then report back when you can Best Regards,Tobycar going for a full service on wednesday will be getting that all replaced, thanks for the help will let you know if it solves it :angry: ;) Quote Link to post Share on other sites
Galliano Posted April 20, 2008 Share Posted April 20, 2008 good luck :angry: Quote Link to post Share on other sites
