Glanza_v9797 Posted January 5, 2020 Share Posted January 5, 2020 Can anyone help me out here I want to know why my engine is doing this noise?? I've changed belts,altenator and the timing belts pretty new? Cheers 20191215_093156.mp4 20200104_162717.mp4 Quote Link to post Share on other sites
B11G KY Posted January 5, 2020 Share Posted January 5, 2020 If one of you auxiliary belts is to tight it can make that noise. Happened when to me with my power steering pulley belt when i junked my AC. Try slakening a little might just be to tight Quote Link to post Share on other sites
Glanza_v9797 Posted January 5, 2020 Author Share Posted January 5, 2020 I will give it a try but i was told it could be the cambelt too tight would it be obvious if so? Quote Link to post Share on other sites
B11G KY Posted January 5, 2020 Share Posted January 5, 2020 Well you mentioned you just changed belts and alternator so I assume the problems lays there, if it was running fine befor. Alternator belt and power steering belts are easy to loosen I'd start there. Quote Link to post Share on other sites
Glanza_v9797 Posted January 6, 2020 Author Share Posted January 6, 2020 Okay mate I will give it a go and see where it goes Quote Link to post Share on other sites
