Shaun Posted September 8, 2005 Posted September 8, 2005 is a glanza cam belt the same as a normal starlet ep91 belt cheers shaun Quote
Ivan Posted September 9, 2005 Posted September 9, 2005 Yes, they are. If you go timing belts, you can go aftermarket uprated, or genuine toyota, or aftermarket cheap stuff.If you can get the Toyota one, they are the best, otherwise a cheap aftermarket one. The engine is freespinning meaning that no damage will be caused to the valves or the head if the timing belt snaps.Regards,Ivan Quote
scutch0 Posted September 9, 2005 Posted September 9, 2005 really??i didnt think that was the case on the 4efte?? or the 4efe?? Rich. Quote
Ivan Posted September 9, 2005 Posted September 9, 2005 all 4e engines are free-spinning.In saying that, i believe 5e, and possibly 2e and 3e are aswell but i cant confirm it for certian.Ivan Quote
