ChineseMafia Posted April 22, 2008 Posted April 22, 2008 i find this to be verry unfair that this question has been posted twice and yet no one has found it neccary to help the fellow brethen by answering a simple question all we wanna no is : do the 4EFE and 4EFTE engines use the same bearings and ringsalso do the 5EFE and 4EFTE engines use the same bearings and ringsplease please please some one help me im in a bad way with my engine Quote
Spoonz Posted April 22, 2008 Posted April 22, 2008 i dont think they do mate. has there low comp pistons Quote
Tintin_SR Posted April 23, 2008 Posted April 23, 2008 i dont think they do mate. has there low comp pistonsi ad say so Quote
sx_turbo Posted April 30, 2008 Posted April 30, 2008 definately not.none of the engines use the same piston rings.the turbo ones are stronger than the none turbo ones, as they have a higher heat to deal with. the same goes for the pistons.the rods are different, on the 5e series and the 4e seriesthe big end bearings are are the same on the 4efe and 4efte. but there are 4 types. they should be marked numbers 1-4, but when i rebuilt my engine there was no mark that made any sense.i hope this helps. Quote
ChineseMafia Posted April 30, 2008 Author Posted April 30, 2008 starlet rick indicated to me that the bearings and rings were all the the sameso now im kinda confused Quote
sx_turbo Posted April 30, 2008 Posted April 30, 2008 starlet rick indicated to me that the bearings and rings were all the the sameso now im kinda confusedok, starlet rick is half right.the 4efe and 4efte big end bearings,and rods are the same. the piston rings and pistons are different.the 5efe gear is completely different.what you can do though is put 4efte pistons and piston rings on a 5efe rod. effectively making a 5eftewhat i have just said is what i wrote above. Quote
ChineseMafia Posted May 14, 2008 Author Posted May 14, 2008 the 5efe rods are longer than the 4e ones and even if they were the same its the crank that makes the didderence in displacment not the rods Quote
