ChineseMafia Posted April 24, 2008 Posted April 24, 2008 i got this info fron another page i can remember where but the first line has me confused Cylinder head bolt - first, 500kg/cm ; second, turn 90 degrees Cylinder head x camshaft bearing cap - 130kg/cm Cylinder head x number 2 idler pulley - 280kg/cm Cylinder head x cylinder head cover - 70kg/cm Camshaft timing pulley x camshaft - 510kg/cm Cylinder block x number 1 idler pulley - 185kg/cm Cylinder block x crankshaft bearing cap - 580kg/cm Cylinder block x rear oil seal retainer - 75kg/cm Cylinder block x oil filter union - 250kg/cm Connecting rod cap x connecting rod - 400kg/cm Crankshaft x crankshaft pulley - 1550kg/cm phew ! ... I've taken these settings from the 63026 Toyota Japan Engine Repair manual (4E-FTE) and cross referenced them to the RM238E (english 5E-FE) Paseo Engine Repair manual ... guess what ! ... they're the same settings except for the Cylinder head bolt (450kg/cm for EL44 Paseo, yet in Japanese manual they specify 500kg/cm for all 4E motors and the 5E-FHE !) could some one please explain this to me cause i get all the other torque settings except that oneor if any body has any info on replacing the head that would be nice thanks guys
