Gav Missen Posted May 9, 2022 Posted May 9, 2022 Hi everyone so I’m doing a bit of an overhaul with my suspension I’ve replaced everything wishbones droplinks anti lift kit 24mm arb etc well.. I’ve just fitted it all up and the near side arb is practically touching the wishbone where as the offside has a bit of space, will this change once the cars on the ground? I did notice when I removed the old anti roll bar that there were some make shift rubber covers over the arb in that area offside nearside thanks Gav Quote
