Charlie Thompson Posted August 23, 2022 Posted August 23, 2022 Welcome to the sale of my immaculate Japanese import Toyota Starlet Glanza V, which I believe to be one of the best condition Glanza's in the country. The only reason the vehicle is for sale is due to lack of use and only covering 470 miles since I had it imported in 2020 and since been in the UK it has been dry stored and never used in the rain or damp conditions. The car drives flawlessly with no unwanted noises or smoke and the gearbox is extremely smooth. The car is absolutely immaculate underneath, inside and outside. There is the odd little mark inside from general wear. The outside is immaculate with not one single mark at all and the finish of the paint work is outstanding. Underneath is also immaculate (see pictures) The vehicle was imported completely standard apart from aftermarket wheels and steering wheel and was in excellent condition overall. Since owning the vehicle thousands has been spent including a full exterior paint job by Phil Bell panel and paint which cost £2900 and was completely stripped down for the paint job. The reason for the paint job was because I'm extremely OCD and a perfectionist (see the pictures at the end for the vehicle when i received it back from paint and when i first bought it at). I have clear wax oiled the vehicle for long lasting protection (I used clear so it shows that there is nothing to hide underneath) There is absolutely no rust underneath or on the exterior of the vehicle. The car has been maintained regardless of cost since been in my ownership. 3x oil and filter changes. Gearbox oil change. brake fluid change Cambelt, water pump and oil pump. Fuel filter. Track rod ends, inner tie rods and boots. Handbrake cables. 4 wheel alignment. new OEM clutch. rotor arm, dizzy cap, spark plugs and coil pack. The vehicle has been very slightly modified since I've owned it but every original part that has been removed has been kept and will be included in the sale (see pictures). Which also includes OEM wind deflectors and brand new Powerflex bushes. The list of modifications and spec below. Walbro uprated fuel pump. Sytec adjustable fuel pressure regulator. Tuning development 3" cat back exhaust (sounds lovely and not to loud) Tuning developments 3 core radiator. Short route front mount intercooler. WEPR ramhorn manifold and decat. RW developments catch can and modified cam cover. Yellow speed coilovers. Rota grid alloys with 4 uni royal rainsport 5 tyres which have only covered 470 miles. adjustable panhard rod. OEM rear strut brace (very rare). Magnecore HT leads. Dump valve The vehicle will come with 12 months test. I've tried to be as honest as possible with the description. FIRST TO SEE WILL BUY. Price is- £10,500 For more information please call or message Charlie on 07783647990. Quote
