4EFTE Sol Posted April 24, 2008 Posted April 24, 2008 Umkay so guys and gals seriously this is going to take 5 minutes of your time.Step 1.Open bonnet and unscrew the only screw that holds the unit inStep 2. Carefully but firmly wiggle the light from left to right and it will come out eventually just stick with it, YOU DON'T NEED TO TAKE THE HEADLIGHTS OUT!!!Step 3.Once the light is out remove the plug from the back of the light and affix it to the new one, i would do a quick lights check before putting the unit back in. Step 4.Put the light in bottom first as thats where the plug is, then (if nearside) place in right before left as it has tags on the back, once in push the light right in as there is a clip that clips into a fixing.Step 5.Then enjoy! its that simple Much improvement me thinks
