Energized Customs Posted April 28, 2008 Posted April 28, 2008 Hi, i have a jam racing actuator fitted and it seems that the hi-lo boost control has been bypassed. I would like to reconnect the hi-lo boost as i do a lot of town driving and don't require 1 bar of boost in a 30mph zone!!! LOL. Could someone provide information as to how to do this. Photos would be great.Cheers Quote
StarletRick Posted April 28, 2008 Posted April 28, 2008 if you still have the stock solenoid on, you need to put a piece of hose going from the pipe down the side of the pulley cover to the solenoid. then you need to put the nipple going from the intake pipe to the other nipple on the solenoid. then make sure the port on the front of the actuator is still connected to the compressor housing. youll have your hi lo back, but youll loose hi boost in 1st and 2nd gear. Quote
