My battery seems to be dead. Losing its charge very quickly. Only problem is i have no idea what battery i need to get to replace it? Does anyone know which battery it is? Everywhere seems to list it as a 004L, but that seems way too big! The original Yuasa battery on there is a 40B19R.
Any help much appreciated
before you go and get a new one you shooed try and salvage the one on it the now, have you checked the electro-lite level??
I have been in the automotive trade for nearly ten years and i've never heard that expression before? Could you enlighten me. I think its pretty fooked though. I've tried charging, and the voltage drop reading on my multimeter is about .03 volts per minute.
I think Tintin Sr means have you topped it up with de ionised water in the top.
Another thing i'd get your alternator checked as it may not be charging your battery fully. May be on the way out. If it is give me a shout as i have a low milage one.
Bourkey
Yes yes thatâ??s what am taking bout the fluid in the each cels is clad an electro-light its dilute sulphuric acid but what you top it up its just ionised water that you need, as its not the sulphur that evaporates its the hydrogen and the oxygen
