Spoonz Posted May 7, 2008 Posted May 7, 2008 Sup.Was driving up a dual carriage away earlier on give it a bit of stick (up to 70 was the speed limit) wen my oil pipe chucked all my oil out it never bluw of it came loose and chucked all the oil out (its a TD04) now has soon has i heard hte car start to make a wierd noise i turnt it of but im guessing the damage has already been done.Whats the worst that ive done has thats what im expecting to see and how will i tell what ive done for example if i done a piston ring will the piston need removing??? Quote
ecksjay Posted May 7, 2008 Posted May 7, 2008 have you repaired the pipe, topped up the oil and started the motor?you may have got lucky mate, providing it didn't run empty. Quote
Spoonz Posted May 7, 2008 Author Posted May 7, 2008 TBH i dont wanna start it up just incase i do more damage Quote
StarletRick Posted May 7, 2008 Posted May 7, 2008 starving the oil will cause many many problems. it depends how quick you got it. put oil in and start it up. what have you got to lose? if you need an engine rebuild, it doenst matter how much damage is being done. Quote
Spoonz Posted May 7, 2008 Author Posted May 7, 2008 well soon has i heard the tapping noise u get with low oil i paniced and just stall was avout 2 seconds long guess your right rick grrrr engine rebuild is the last thing i need right now Quote
StarletRick Posted May 7, 2008 Posted May 7, 2008 the only way to check bearing damage is to strip them out. just fill it up. and start it . if its fucked youll know about it and eitherway youll have to rebuild it mate. Quote
