AlexGTAdv Posted May 7, 2008 Posted May 7, 2008 Have just bought a HKS SSQV dump valve with a starlet flange. Went to fit it to my EP82 and i'm not sure what to do with the pipe that comes from the intercooler pipe? I blocked it off and when i revved it up it chattered like mad and didn't sound like anything was comming out of the dump valve, just the air filter! Can any body shead any light?? Cheers. Quote
ecksjay Posted May 7, 2008 Posted May 7, 2008 it should be mounted to the pipe coming off of the intercooler pipe, thats what is pressurised and activates the BOV :/What the chuff have you mounted it to? hahaha!If you blocked it off, you were technically running no dump valve, thus getting 'turbo stall' as air returned back into the turbo compressor.Show us a pic of how you've mounted it, because at present, its very wrong. Quote
AlexGTAdv Posted May 7, 2008 Author Posted May 7, 2008 it should be mounted to the pipe coming off of the intercooler pipe, thats what is pressurised and activates the BOV :/What the chuff have you mounted it to? hahaha!If you blocked it off, you were technically running no dump valve, thus getting 'turbo stall' as air returned back into the turbo compressor.Show us a pic of how you've mounted it, because at present, its very wrong.I'm not sure how to put a pic on but i mounted it where the old bov sits as it came with a flange which allowed it to be put here! Is this totally wrong then. lol? Quote
ecksjay Posted May 7, 2008 Posted May 7, 2008 so it sits on the turbo-intercooler pipe yes? (thats where its supposed to go).if you email me a pic you have i can tell you whether its wrong or not ;)ecksjay@gmail.com Quote
