hi, i will be getting a ct20 and a ct9 turbo at the end of the month,
can i use the exhaust side of the ct9 with the compressor side of the ct20? was going to use on a wepr external wastegate set up
i will find out for you tommorow mate when im at work.
i have a feeling it can take the size of the shaft with a lot of boreing out but im unsure weather the ct20 bearing housing sits in the ct9 turbine housing or if you use the ct9 bearing housing wheather it will fit ct12 compressor. i will try and see if they fit tommorow.
