Glanza Al Posted May 15, 2008 Posted May 15, 2008 Right, I have sourced a Hybrid CT9 for the Glanza. But I have no idea what else I need before fitting it.I was thinking:CT-9 Hybrid (comes with stainless downpipe and screamer)E-manage blueBoost controllerJAM FCCAnything else I need or indeed need to consider?Cheers guys,Alex. Quote
Guest Enzo Posted May 15, 2008 Posted May 15, 2008 uprated actuater,and manifold are the only two things missing i think matey,also you wont need the fcc as the emanage has one built into it to bypass fualcut,if you intend on running it past 13psi it might be wise to invest in some uprated cooling.oh and a front mount filter would be best to get the most out of the turbo. Quote
RobSR Posted July 10, 2008 Posted July 10, 2008 yup, dont need an FCD with the emanage...i presume you have decent brakes and all that?Acutally, this is something toby wrote up, think its pretty good :-Below is what we list as a general guide for 200hp with chassis and brakes to match, for 240hp swap the CT9 parts for a TD04 kit :â?¢ Toy Tuning Hybrid CT9 or Equiv. Toy Tuning Mild Steel Manifoldâ?¢ Decatâ?¢ Cat Back system (Greddy/5Zigen)The car is now expelling gases more efficiently.â?¢ Power Enterprise Air Filterâ?¢ Heat Reflective tape for Inlet Track. Replocate to front bumperCar is now breathing more efficientlyâ?¢ Raise the Rear of the Bonnet with washersâ?¢ Front Mounted Intercooler â?¢ Sard Thermostatâ?¢ Sard Rad CapCar is now cooling more efficientlyâ?¢ New Spark Plugs (NGK 7 â?? one grade colder)â?¢ New HT leads (Magnecore 8.0mm)Ignition system now worksâ?¢ Uprated Fuel Pumpâ?¢ Sard Fuel Pressure Regulator. Greddy Emanageâ?¢ Rolling Road SessionCar now fuelling adequatelyThis should net you around 180bhp - 200bhp on 18 psi max. This then leaves the brakes and chassis which will need to be sorted to cope with the power. I would recommend at a min:â?¢ 3G 10GR Front Disksâ?¢ Mintex Padsâ?¢ New OEM Rear Padsâ?¢ Braided Brake Linesâ?¢ Cusco BMCSYou can now stop!â?¢ D2 Coilovers / Koni Shock Absorbers with Whiteline Springsâ?¢ Front and Rear Strut Braces (Cusco)â?¢ Whiteline Panhard Rodâ?¢ Cusco Lower Arm Barâ?¢ Anitlift kitPower to ground greatly improved.Thatâ??s a basic list of what we recommend, obviously there are many more parts that will net you a good handling car that can stop with power to match but that should give you a good idea.For 240hp you can consider a forged engine, you may okay with a good tune but it depends on the current condition of the engine..T Quote
