Sup.
Has some of you know i broke a big end bearing after buying some new ones i found the crank needed re grounded so wanted to know would it be ok to put another crank in my car and use my new bearings??
did you buy oversize bearings for the regrind?
in theory an undamaged crank should work with some new regular size bearings.
test then first though to avoid a problem.
