chief Posted May 18, 2008 Share Posted May 18, 2008 his has just happened today and i'm a little concerned about it. When the car is on load and the turbo is spooling up not only do i have the normal whistling sound of spool up i also have a really sound of something that sounds like an air leak or someone letting down a car tyre. Really confused as there;is no smoke. Seems to be constant boostDoesnt appear to be slower " could be wrong"Cannot locate any holes on any of the visible pipes and nothing seems to be off. Car is an EP91 Glanza and bog standard under the hood. Just concerned and want to get this sorted before something happens - was worried i have a fooked turbo blade or something....Doesnt sound like a blowing exhaust either. Quote Link to post Share on other sites
StarletRick Posted May 18, 2008 Share Posted May 18, 2008 sounds liek an air leak. youll have to check all the hoses etc to find it. dont worry though, it isnt fucked. its a simple fix, you just need to locate it. Quote Link to post Share on other sites
STEVIE Posted May 25, 2008 Share Posted May 25, 2008 his has just happened today and i'm a little concerned about it. When the car is on load and the turbo is spooling up not only do i have the normal whistling sound of spool up i also have a really sound of something that sounds like an air leak or someone letting down a car tyre. Really confused as there;is no smoke. Seems to be constant boostDoesnt appear to be slower " could be wrong"Cannot locate any holes on any of the visible pipes and nothing seems to be off. Car is an EP91 Glanza and bog standard under the hood. Just concerned and want to get this sorted before something happens - was worried i have a fooked turbo blade or something....Doesnt sound like a blowing exhaust either.This happened to me too after fiddling about i found there was a leak in a vacum hose going to my turbo timer . So i would say u have a leaky hose somewhere Quote Link to post Share on other sites
