michael_ngai Posted May 31, 2008 Posted May 31, 2008 I've found my EP91's gear box got some problem and I am thinking changing a racing clutch. Do you guys have any idea where I can find those part or wt kind of parts do i need?will be realy appreaciate the help. Quote
Tintin_SR Posted May 31, 2008 Posted May 31, 2008 is the prob going in to 2nd gear at eney rpm over 2? Quote
StarletRick Posted May 31, 2008 Posted May 31, 2008 a clutch wont solve a gearbox problem. what is the issue you have, maybe we can help :angry: Quote
michael_ngai Posted May 31, 2008 Author Posted May 31, 2008 sometimes wierd noise come out when I change the gear and also, sometimes feels like got a bit stuck when i change gear (not smooth). Sorry for my bad english because its not my first language Quote
Tintin_SR Posted June 2, 2008 Posted June 2, 2008 its ok pal what sort of noise is it making is it a crunching sound when changing gear, put a video up if it helps Quote
michael_ngai Posted June 2, 2008 Author Posted June 2, 2008 Its like the gear is not changing properly and hard to switch gear, like something stuck in the gear box. Quote
Tintin_SR Posted June 4, 2008 Posted June 4, 2008 hmm thats a weird one, ad try sum thing les drastic 1st like changing the oil Quote
StarletRick Posted June 4, 2008 Posted June 4, 2008 firstly, check your linkages. they could be on their way out. then drain the box and get some decent oil in there. go for a drive to warm it all up and see if its ok then. if not, then its something more serious. is it only in lower gears (ie 1st and 2nd)? Quote
Guest Enzo Posted June 4, 2008 Posted June 4, 2008 is it goin into second, and fith, these two sincros are pretty week ive had to replace 1 box over the years because of this Quote
michael_ngai Posted June 5, 2008 Author Posted June 5, 2008 if i go to the garage and ask them to change it the gear box oil for me, will they able to do it?Also, I found out that i need to make my own subframe if i am changing to seats. Is there anyone here can help me to make my own one?My base is in London Quote
