AntEP82 Posted June 6, 2008 Posted June 6, 2008 Hello people need so advice on a small pipe that needs sealing/blocking somehow. Have taken a couple of pics but r bad quality so sorryHope that is ok Rich so what do you think?What sort of stuff do i need? I came into your work earlier but you werent there thanksAnt Quote
scutch0 Posted June 6, 2008 Posted June 6, 2008 you'll be loosing boost pressure with that like that too.i suggest grab a short piece of silicone tubing off si's car push it on and then find a bolt that'll fit tightly inside the tubing, then put something like a jubilee clip around it to clamp it down.pm me if you get stuck mate. Quote
AntEP82 Posted June 6, 2008 Author Posted June 6, 2008 Thanks Rich, probs have to sort it out 2morro because Si's gone out. Quote
briggers Posted June 7, 2008 Posted June 7, 2008 i just scerew one straight in without the silicone tube when i had to mount the dump valve to another place so on the rocker cover to the right there are 3 pipes so i had to block one of them off just get a long screw which is slightly oversized for the hole so you cn screw that damn thing in tight Quote
