I have done a search and can't find anything of relevance :lol:
I recently bought 3G disks for my car and they are a fair bit bigger.
The 3G disks are 254mm and seem to be about 1cm too big, what are the standard size of the oem disks as I cannot measure these at the moment due to not having the right wheel brace.
Details:
Starlet 1.3I
S reg 1998
Calipers and Carriers
Cheers
Rich.
  • 2 weeks later...
i tihink you have the earlier 238mil discs later ep91s came with 254mil discs so i think theres your problem
i have the same problem i just brought a set and there too big aswell i do have a couple of plans up my sleeve if the problem can't be solved,
one of which will mean machining them to size, the other is try a set of later spec corolla gti calipers as they 'might' fit and give the extra clearance needed.
They sent me the Turbo ones. The one I have on now are 238 but I thought I would of had the late ones as it is a 1998 and has the carriers. :S
