59bhp Posted June 13, 2008 Posted June 13, 2008 Yes they do..........ishall the bolts holes line up a treat apart from the front left hand one (as if you were sitting in the seat) it needs to go left 15 to 28mm on the frame that i have. To be honest you could probably get away with gettin the "persuader" on it but as i have acces to a grinder and a welder im gonna just reposition it that way. Heres a pic:so there you have it, ep91 frames do fit ep82. Kinda begs the question why toyota would make such a tiny adjustment to the floor plant though. The seat and frame i have has about 20 points of adjustments as well and i couldnt get it to fit right so it definatly is different. Its a bit weird though! Quote
